-   -   Difference between Trim Pump and K-Plane Pump (https://www.offshoreonly.com/forums/general-q/101457-difference-between-trim-pump-k-plane-pump.html)
Poorsche 04-23-2005 02:52 PM
My drive trim pumps are letting the drives creep out of postion when I'm running the boat. I've got a pair of pumps in storage but I'm not sure which they are--trim or K-plane pumps.
What's the difference between the two--if any? I was going to do a quick and dirty swap to see if that solved problem rather than mess with the relief valve at the moment.
hillbilly24 04-23-2005 06:12 PM
Re: Difference between Trim Pump and K-Plane Pump
I beleieve they are the same except the relief valve setting.
Poorsche 04-23-2005 06:48 PM
I'm wondering if the genius that reinstalled my hydraoulic lines hooked wrong pumps up to wrong cylinders.
Guess I need to take lines of pumps and see which ones are hooked to which what-chma-callit.
