quadrajet choke? >
quadrajet choke?
quadrajet choke?
Old 04-25-2005 | 02:16 PM
Default quadrajet choke?
I have a 1989 motor that I am switching to vortec because my heads are shot. Here is my problem: On all the vortec intake manifolds you need an electric choke. I am doing this on a budget so I need to stay with the stock q-jet this year. My q-jet has a heat activated choke. What can be done? can I get an electric choke, can I run without it? any ideas??? I boat on long island. in about 75-85 degree weather, if it matters.
Thanks Harry
tahoeguy318 is offline
Old 04-25-2005 | 03:07 PM
Default Re: quadrajet choke?
Simple, take the choke off
1BIGJIM is offline
Old 04-25-2005 | 03:11 PM
You've got 3 options:
1) remove it
2) Mount a divorced choke on the vortech manifold (available through summit/jegs/etc)
3) Add an electric choke (summit/jegs/carb shop/junkyard/etc).
Any of the above options should be under $30.
Gary
Gary Anderson is offline
Old 04-25-2005 | 03:22 PM
I would rather just take it off then. What problems will I most likely have other than a hard start?
oh and thanks
Old 04-25-2005 | 03:35 PM
Not a big deal. Just wire it so the choke stays wide open.
You'll just have a rougher cold idle for the first few minutes. Most boaters I know let their engines warm up at a slightly higher rpm anyway.
You also may find you have to pump the throttles a couple times to pump a little extra fuel at startup.
Gary
Old 04-25-2005 | 03:40 PM
Whiteknuckle's Avatar
I took the choke plate and linkage off my q-jet. Even in 50 degree weather, with about 5-6 pumps of the throttle and off she goes. Take it to a high idle after oil pressure comes up and let it warm up about 10 minutes. I had the heat riser passages in the manifold block off also, no problem even in Michigan.
Whiteknuckle is offline
Old 04-25-2005 | 05:52 PM
Official OSO boat whore
Can you get a spread bore intake manifold for a vortec? The cost of a new intake manifold will proably negate the cost of a used marine carb. Something to think about.
Cord is offline
Old 04-25-2005 | 11:18 PM
Just bolt on a electric choke coil wire off the alt or oil press switch easy to do
fstboater is offline
Old 04-26-2005 | 04:56 PM
cdscarab's Avatar
Did the same as whiteknuckles, works great. It may have actually improved performance slightly. Smoother air flow into the primaries, can't hurt.
cdscarab is offline
Sacred Ground
Wanted
1
05-17-2008 10:05 PM
bcarpman
11
10-04-2006 02:23 PM
sonic28
15
12-04-2003 09:12 AM
zoomba
3
07-09-2003 08:44 PM
