How to Build 500hp from a 454/420hp?
I recently purchased a set of 454cu/ 420 hp long blocks. I want to replace the cams, pistons, and re-work the iron heads etc.
Is 500hp possible with pistons, intakes, cams and flow work on iron heads ? I will be installing these in a 89' Formula 272 with Gil exhaust manifolds. Lastly, Will Hp500 Dart intakes fit 454/420's? |
Re: How to Build 500hp from a 454/420hp?
| All times are GMT -5. The time now is 09:56 AM. |
