-   -   Changed circ pump - Scaling in water passages? (https://www.offshoreonly.com/forums/general-q/102852-changed-circ-pump-scaling-water-passages.html)
RMM 05-10-2005 10:05 AM
My circulating pump went and while installing the new one I noticed a decent amount of deposits/scaling in the the water passages (where I could reach my fingers into) and also what seemed like alot of black soot that is scraped from the edges of the holes.
Scraped a lot of it away but anything I can run through the engine to disssolve/clean this? Is a 3 year old long block Merc 454, RWC run on the Chesapeake. Currently there is no strainer for the RW just where it comes through the Bravo I. Would installing a inline strainer help? If so what size/capacity do I need?
NightHawk 05-10-2005 11:06 AM
Re: Changed circ pump - Scaling in water passages?
That's just typical RWC engine corrosion and deposits. You'll see the same thing if you look inside the thermostat housing and a strainer won't help. Be careull about doing much scraping, you could loosen enough material to cause a clog elsewhere in your system.
red thunder 05-10-2005 08:35 PM
Use Salt Away to flush motors. Not that expensive, but works good. Read directions.
