-   -   Tab Mounting (https://www.offshoreonly.com/forums/general-q/103114-tab-mounting.html)
Coolerman 05-13-2005 02:20 PM
Tab Mounting
Just out of couriosity, where do you all of like to mount your tabs? It seems that most people mount them out as far as possible and put them flat. I have seen some others that like them mounted in and at angle. Just courious.
HighPriority 05-13-2005 03:16 PM
Re: Tab Mounting
On our race boat we put them IN and Flat, but we like to be a little different.
Coolerman 05-13-2005 04:03 PM
Re: Tab Mounting
Thanks Warren. Yeah that does seem different. Is your boat prone to any odd handling tendancies or does go through the smooth and the rough really well?
I've heard some people say that mounting them in will make the boat more prone to chine-walking? Also, wouldn't the boat go faster if they were mounted on the furthest to the outside to reduce drag? Just courious because fountain claims the best spot is flat and furthest to the outside.
HighPriority 05-13-2005 06:16 PM
Re: Tab Mounting
Saxman; Our boat handles very well in all water con., and will turn on a dime, in fact boat handling is why we are winning races. The main reason we mounting the tabs the way we did was due to the way the bottom is made. What we did was mount the tabs so they make the boat think it is 3' longer then it really is. This of course works good in big water.
Outdrive1 05-13-2005 07:26 PM
Re: Tab Mounting
Originally Posted by Too Old
I've seen them mounted all over a transom. I tend to stick with the builders chosen location.
Those number sixes are sick!!!!!!!!!!! Have they ever been in the water? :D
