-   -   What's this thing in my bilge? (https://www.offshoreonly.com/forums/general-q/103266-whats-thing-my-bilge.html)
Zanie 05-16-2005 07:22 AM
2 Attachment(s)
What is this little puck in my bilge?
There are two of them in the forward section of the bilge. same spot on both sides. Looks like a #10 screw coming out of it.
There is no marking or any indactor in this area on the outside of the boat.
What is it?
batty 05-16-2005 08:08 AM
Re: What's this thing in my bilge?
it looks like some one left a grinding disk and covered it with resin :eek:
not sure what the heck that is. I had to go check my excalibur to see if I had that there but I dont . its hard to say what previous owners had done to boats. I know I found a few odd things in the bilge.
good luck
Brad
Poorsche 05-16-2005 08:10 AM
Is it possible it's part of "Bonding System"?
robyw1 05-16-2005 08:22 AM
maybe a thru-hull transducer for a depth gauge? then again i don't know why there would be two.
Roby
fund razor 05-16-2005 08:25 AM
Looks like it was for mounting something else, rather than looking like some kind of transducer.
I have never seen a transducer that looked like that.
fund razor 05-16-2005 08:26 AM
Roby
I have two... one is for the digital depth gauge in the dash and one is for the sounder.
But one of mine hangs off of the transom.
Poorsche 05-16-2005 09:29 AM
Might be a mounting plate for transducer with hole drilled and then sealed at factory for optional electronics package install.
Smitty 05-16-2005 12:17 PM
Could be a plug for a water intake port.
Zanie 05-17-2005 07:10 AM
They have been in there since the boat left the factory. The factory gray bilge paint was covering them when I got the boat.
I'm looking for a place to install a shoot thru transducer so I'll need to remove coring to do that. I was kinda hoping I could just cut one of these out to do it.
I was hoping somebody might have seen these before.
Thanks!
DS
Strip Poker 388 05-17-2005 08:04 AM
What kinda of boat is it??
It a nylock nut on it.
Maybe a zink? Guessing .Can ya see the bolt from the outside ?
