Tech Tip - VALVE TIMING
1 Attachment(s)
In an effort to simplify what actually happens inside a 4-stroke internal combustion engine, we invite you to “take a walk” inside a typical engine.
We will discuss valve events, piston position, overlap and centerlines. Although we do not have enough room to explain cam design in detail, we will clear up several of the most often misunderstood terms. We hope to give you a more clear understanding of what actually occurs in the operation of a four-stroke engine. We will graphically illustrate the relationship between all parts of the engine and to try to help you understand how the camshaft affects the power of the engine. Download the attached PDF file to read or print the rest of this article. |
Re: Tech Tip - VALVE TIMING
Alas, I can't download it cause I'm a p.o.s. free member here :rolleyes:
Can you upload it to yousendit.com and provide the link, I'll be sure to mirror it. |
Can you upload it to yousendit.com and provide the link, I'll be sure to mirror it. Its 5 pages . Try there web site the info is there. |
thanks for posting all this stuff, it is very informative and I'm sure is explaining alot of mysteries for alot of people.
We'll have all of the articles posted on the web site at www.keitheickert.com sometime later today. I'll post a direct link for you once they are available.
The latest articles have now been added to the tech tips section of our web site. For those of you that asked you can now view the available articles at http://www.keitheickert.com/tech_support/default.htm
Watch for more informative pieces from the KE team! |
| All times are GMT -5. The time now is 05:48 AM. |
