-   -   bravo 3 problem (https://www.offshoreonly.com/forums/general-q/103640-bravo-3-problem.html)
JIM H 05-19-2005 09:32 PM
bravo 3 problem
i bought a 1995 formula w/a bravo 3
when i put the boat in today it goes in reverse when i put it in forward and reverse when i put it in forward
someone told me that the cable is not installed right on the dash controler
can give me some adivce how to repair
thank you
hillbilly24 05-20-2005 12:01 AM
Re: bravo 3 problem
pull the shifter out and you will see two throws that the cable could be atached to, hook it to the other one. I don't believe they make counter rotating props for bravo III's since its's kind of a mutt point, so you cant just switch the props. I wonder how the hell it got the way on a 95' ?
JIM H 05-20-2005 04:28 AM
Re: bravo 3 problem
thank you,
