-   -   4 x 4.5 Exhaust Adaptor (https://www.offshoreonly.com/forums/general-q/104014-4-x-4-5-exhaust-adaptor.html)
dean campbell 05-24-2005 04:44 PM
Does anyone manufacture a bushing to adapt a 4.5" clamp-on muffler to a 4" exhaust system?
I know it's not the correct way to do it, but it would get me on the water for now.
thanks,
dean
tcelano 05-24-2005 05:36 PM
Re: 4 x 4.5 Exhaust Adaptor
I haven't seen an manufactured adapter, but if you need to get on the water ASAP, get a piece of 4" Trident Marine Exhaust hose from Defender Industries. The outside diameter of that hose is 4.5". You can clamp your muffler on over it, or get a piece of 4.5" ID hose to bridge the gap, depending on the configuration. That will work at least until you find or have an adapter made.
I know this because my boat had 4.5" transom holes. I made my own 4" pipes, and welded in some inline mufflers. I put the hose on over the exhaust tip on the inboard side, and it all press fit in there perfectly with some 5200 just so I wouldn't be tempted to take it apart... Mine have flanges that bolt to plates on the transom from the outside.
PatriYacht 05-25-2005 05:44 AM
I did it with a piece of 4" i.d .25 wall aluminum tubing. Cut a piece in half so that it clamps on the exhaust pipe as you tighten the muffler.
dean campbell 05-25-2005 09:58 AM
thanks guys, i'll try one of these ideas, also you gave me some other ideas that may work too.
yeah, just looking for a temp. fix untill i get some permanent mufflers.
Thanks!
dean
