-   -   Mesa Racing Engines Latest Project (https://www.offshoreonly.com/forums/general-q/104078-mesa-racing-engines-latest-project.html)
MESABALANCING 05-25-2005 09:27 AM
1 Attachment(s)
Ok guys we've been busy and haven't been posting but here is our latest project arrived yesterday we're building a pair of twin turbo big block aluminum chevy EFI engines they're going to be 380 ci as planed so far and we expect to make in the 1300 t0 1400 hp I'm going to document and show as much as possible and at the end we'll see how close we come . The customer wants to run 170s and have the fastest accelerating boat he's aver had we're going to give it our all . Also all the wiring for the dash panels we'll be finishing for him. Hope you gear heads enjoy . Sincerely Laz Mesa
Stormrider 05-25-2005 09:33 AM
Re: Mesa Racing Engines Latest Project
Laz, 380ci?
1BIGJIM 05-25-2005 09:34 AM
'380 ci' ?
tomcat 05-25-2005 09:49 AM
Hi Laz: You must really want to rev those puppies! I know this is sometimes necessary with available props and ratios to get the big speed, but I'm thinking about Mercury's 500 CID race engines that used 4.6 bore with 3.75 stroke. Wouldn't that work or does the customer want to base this on an engine program developed for under 400 CID racing class?
MESABALANCING 05-25-2005 12:29 PM
Originally Posted by sutphen30
as a turbo guy,,about friggen time..i'm sure you'll hit that goal.have you figured on how much boost you want to run, :D not how much you may have to run. :eek:
maybe now the turbo will start coming into the marune industry full swing.
alot of 427 small blocks making that kind of hp now,thanks to programmable efi. :D
We've been building turbo engines for years now for drag racing and I have several customers that have broken every E.T. and mile and hour record in their classes for years this is going to be one bad set up we plan on turning the engines 8500rpm with the gear we have in the drives to see speeds in the high 160 to low 170s I'm going to show flow numbers rod ratios cam specs and at the end the final dyno videos and dyno numbers.
Stormrider 05-25-2005 01:03 PM
There are plenty of Turbo Diesels running out there in the marine environment.
tcelano 05-25-2005 05:20 PM
A 380 c.i. big block should be absolutely bulletproof!
At 4" bore x 3.75" stroke, you are going to have a mean piston speed of over 5300 ft/min at 8500 rpm. That doesn't seem sustainable. My suspicion is that you must be cooking up something like 4.5" x 3", which lands you squarely at 4250 ft/min MPS. Am I far off?
Has a motor of these dimensions been built before? Could this spawn a new trend for supercharged motors as well? Why not run around with bomb-proof blower motors at 25 psi of boost too? I guess your big challenge is going to be building a valvetrain that can hack it. The poor exhaust valves are going to get hit 4250 times every minute with the turbo's blowtorch.
Can't wait to see!
DanB 05-25-2005 05:46 PM
i should have clarified,,turboes in the marine enviroment. :D i've been doing turboes in cars since 86'.i'm glad your doing it,,i've tried to no avail to talk people into them,,but no go.keep us posted,,again great job.
The've been using twin turbo motors in the boats that pull speed skiers on the west coast for years. Everyone out there uses them. I dont know the specs but I think Pfaff started the craze many years ago. Ive seen them accelerate and they are quick!!!!!
Bulldog 05-25-2005 11:10 PM
GM was workong on a marine engine test program a few years back- As I recall it used a BBC block with short stroke and was less than 400 CI. The heads were special, and were seperately cooled independent of the block. They made big power, but time and patience wore out. They built a couple of prototypes, and the whole project got shelved.
PatriYacht 05-26-2005 07:41 AM
Powerboat magazine did a story about that engine a few years ago. I still have it somewhere. The engines put out big power but the outdrives couldn't take it. That was before #6 outdrives. Btw, the guy that built the exhaust for that boat lives in my neighborhood and does welding and fabrication still.
Sean H 05-26-2005 07:54 AM
sweet.... :cool:
Nordicflame 05-26-2005 08:37 AM
I can promise you they don't run them easy in these events either...
Race after race, they just keep on gettin it on :cool:
MESABALANCING 05-26-2005 09:24 AM
We modified the exhaust system turbos engine management systems waste gates and boost controll system and were currently modifing the cooling system because after disassembling the engine we found some areas that need to be addressed cams and valve trane are also areas of modification were working on my next post will have the exhaust system and modifications with the turbos and the waste gates installed
Dueclaws 05-26-2005 10:44 AM
Laz-
Who built the hull?
Due
MESABALANCING 05-26-2005 01:24 PM
Originally Posted by Dueclaws
Laz-
Who built the hull?
Due
The hull is a Chris Cat and the entire bottom has been cut and redesign with extensive modifications by an individual who is very involved in boat racing and has won countless world championships as a crewchief .
Dueclaws 05-26-2005 01:27 PM
Thanks- I thought it looked familiar.
Due
MESABALANCING 05-27-2005 07:15 AM
3 Attachment(s)
Here are some pics of the exhaust mods we've done you can see the first most noticed is the replacement Garret water cooled ball bearing turbo then the modification to the exhaust with the Tyal adjustable waste gate operated by an Innovative boost controller on the dash that controls both engines at the same time and the addition of the merge type collector flange which we use in the drag race engines I'm confident in the exhaust system alone we have another 100 hp to safely use. Hope you guys enjoy.
MESABALANCING 05-27-2005 09:00 AM
i can see that working in a car,,and i know thermotec wrap work well,,but the heat from that set up at 1000+hp is going to be extreme.is there a plan for putting a water jacket around those pipes???
i do little 2.2l audi turbo motors and at 500hp to the ground,,our exhaust systems glowwwwwww :D very pretty at nite.
garrett makes the water jacketed exhaust turbo housing but they want some bucks for it,, :eek:
These are the latest water jacket design housings from Garrett and the pipes are going to be wraped again after were done they were wrapped when we had them on the dyno the first time and I was supprised how much cooler than water jacket headers they were .
MESABALANCING 05-28-2005 08:49 AM
i can see the center section of the turbo is water cooled..i' m saying,,the exhaust turbine housing is not water jacketed,,like gentry and other marine diesel turboes.why aren't you using them????
You know come to think of it I don't know why Garrett recomended these turbos by design it may be simply they don't have the correct size exhaust housing for the ci were running generally speaking marine turbos have larger exhaust housings and wheels because larger ci are use in that field this project is an open checkbook and it's surely not because of price .
BUIZILLA 05-28-2005 10:11 AM
The water cooled turbine housings are incredibly heavy..... you can't hang those out there on the pipe setups he has showing... they'll crack, and break the flanges right off.... those turbo's are nice pieces, wrap the exhaust and run it...
My only concern would be turbine tip speed, at 8500 rpm engine speed, for loooong distances, your talking over 225,000 rpm on a T5 or T6 frame turbine wheel diameter. The trick is the tubing size, and a/r ratio's matching up...
I wanted to do this setup last year for my Criterion, using a 366" truck block (I have an NOS 366" tall block on the shelf now) .125 over, 3.766 crank, alum. heads, EFI, Hogan intake, maybe 385"-395", single BB turbo, intercooled.... my wallet dried up. I think a 447" may be a better way to go now... JMHO.
Jim Haas
Diesel Power & Injection, Inc.
Miami, Fla.
yahoo 05-28-2005 11:17 AM
How about doing it on an outboard ?
Strip Poker 388 05-28-2005 03:29 PM
Laz neet shet :D , Keep the picks and info coming . I am intrigued :drink:
Rob
MESABALANCING 05-31-2005 03:26 PM
guys here are some pics of the original wiring and gauges that were in the boat and shotly I'll have wiring of our finished work with all the new gauges we went with gaffrig monster gauges platinum face chrome ring and bezzels
Jassman 01-21-2007 10:17 AM
What ever happened to this boat and set up. Thansk Jeff
H2Xmark 01-21-2007 10:37 AM
?? same here, did they ever make any water test.
Trippin 01-21-2007 10:49 AM
That kinda RPM, I wonder how often he'll be rebuilding. Every other Poker Run?
Good luck
otis311 01-21-2007 05:53 PM
I havent heard from Laz at all around here lately.
Panther 01-21-2007 06:55 PM
My father was running tall-deck 454 twin turbo's back in the late 70's, early 80's with a water/air intercooler. They were somewhere near the 600 hp range. The only problems he had back then were finding tall deck blocks. They had to go to junk yards and find junked truck blocks. I believe they were built by Flagship out on Long Island or somewhere near there.
Howitzers 03-11-2007 08:04 PM
Twin Turbos by Gentry
In the 1990's Gentry built a series of twin turbo engines that held up wonderfully. I think they were 355 cid Big Blocks. Maybe tall decks with a bore of 4.25 and a stroke of 3.125 with nice long rods and they were spun up to pretty high speeds. With today's technology, these engines should be sweet. Good luck Laz!
Rexx 03-20-2007 10:42 AM
Interested in progress as well
I'm interested on the status of this as well. I just purchased a used set of turbos for my two 454s. These are the PFM setup (garret turbos) using PFM modded valve covers, PFM water/air intercooler and stock mercruiser manifolds. This system also came with EFI and Paxton fuel pumps. All for the low price of $1025!! :drink:
Just got to piece this all together...but wanting to learn more about Marine Turbo setups before I make all the mistakes :eek:
cougarman 03-20-2007 11:55 AM
Actually Gentry's stuff is starting to surface again.
Carson Brummett out of California has all the molds
for the turbo's ,manifold, and intercooler etc. And Carson
builds turbo engine's too.
But now your Seeing Builders such as Tommy from Chief engines using the gentry parts with his own personal combinations. Tommy had a real nice display at the Miami
boat show with one of his Turbo engine displays going in a
Nortech.
Tommy has made these all cumputerized and fuel
injected and make 1,200 hp. on 93 octane if memory serve's me, Tommy felt that turbo's are the wave of the future for big power with long term engine life.
His display was beautiful !!
Cougarman
