-   -   Strange noises (https://www.offshoreonly.com/forums/general-q/104384-strange-noises.html)
Codered 05-30-2005 03:10 PM
Strange noises
Went out in a buddies new boat yesterday, would rather not say what make, it has a pair of 525's with the ITS set up. Nice set up and runs fine but there seems to be a noise coming from the engine compartment, sounds like water slapping against the hull or a broken u joint. Is a unconventional noise normal with this setup.
Downtown42 05-30-2005 04:16 PM
Re: Strange noises
Did you open up the hatches and check anything? Do noises stop when idling?
Codered 05-30-2005 09:05 PM
Re: Strange noises
yes I investigated the best I could the noise is there in gear and out of gear at idle
rdp145 05-30-2005 09:13 PM
Re: Strange noises
could be the internal flapper in the thru hull exhaust. If it has thru hull exhaust and it doesn't have the rubber flappers on the outside they are prob. internal. They will make all kinds of noise on some brands. If your boat has mufflers or baffles in the pipes it's prob. something else.
Dangerous Dave 05-31-2005 10:41 AM
Re: Strange noises
it's the internal flappers, they make a freakin racket
Codered 05-31-2005 08:07 PM
Re: Strange noises
I gave the flappers consideration and then forgot all about them . I will check them the next time we go out. THANKS for the input much appreciated
