-   -   Older EFI Wiring Help Needed (https://www.offshoreonly.com/forums/general-q/104473-older-efi-wiring-help-needed.html)
Poorsche 05-31-2005 06:49 PM
3 Attachment(s)
I'm trying install a B&G Engine Net Sys to monitor fuel use--I've already measured it in $$$--just curious to see GPH on each angine and at differetn settings.
Problem is the wiring at the ALDA connector and Master/Slave connector wiring don't match anything I can find.
Engines are 1996 vintage MarinePower EFI 454's with a MEFI-1 controller on an Arizona Speed tuned-port injection system.
The Starboard and Port ALDL connectors have a black jumper that seems to just go fromone side of the connector to the other. The Starboard Orange/Black also has a spade pug in wire before coneector like something could be plugged in there. I can't find any documentation on either wire.
The Starboard Master/Slave connector yellow wire is grounded to a frame on the intake.
The port ALDA has the blac jumper and Orange/Blacke just has a junctionpoint in it--with no connector.
The Port Master/Slave connector yellow wire is not grounded but it runs back under manifold somwhere. I chekd it with a meter and it shows no continuity to ground.
So--can anbody helpwith this puzzle ??
