-   -   LS 1 BATBOAT PROJECT by Mesa (https://www.offshoreonly.com/forums/general-q/104676-ls-1-batboat-project-mesa.html)
MESABALANCING 06-03-2005 08:18 AM
2 Attachment(s)
A good friend of ours in the Antigua we built a twin turbo LS1 for his 2004 corvette , called me last month and told me he had aquired a batboat and wanted to use his old engine we had in the shop so he proceeded to tell me he wanted it to be bad to the bone . We built this stroker combo with billet crank Carrillo rods JE pistons and ported and flowed the heads to be able to use the 1.8 ratio rockers with the big valve lift . We're awaiting a Fast EFI system to finish the tuning and I'll give you some numbers when we finish it.
MESABALANCING 06-03-2005 08:23 AM
Re: LS 1 BATBOAT PROJECT by Mesa
3 Attachment(s)
here are some cylinder head pics of the ports and the components being used in the valvetrane
saubouin 06-03-2005 09:04 AM
Since your using aluminum heads & block are you doing closed cooling?
MESABALANCING 06-03-2005 11:52 AM
yes it's a closed cooling system and the exhaust is custom by CMI it'll have circulating pump and raw water pump
Cord 06-03-2005 01:05 PM
Using a LS1 is something I've had in mind for quite some time. What's a engine like that running? I mean the cost for stock vs wild?
MESABALANCING 06-04-2005 08:39 AM
You can build one with some goodies like cam valves springs rockers forged pistons totaly balanced and blueprinted for around $8500 plus exhaust and cooling. And you can go crazy and spend $25,000 on big power big cubes but the factoy block will only take so much I've done some twin turbo strokers for some street guys here in town with the iron truck block and they hold up great.
BUIZILLA 06-05-2005 03:40 PM
now THIS is a cool as **** project, keep us informed.
Jim
pullmytrigger 06-05-2005 05:19 PM
what would you use for exhaust???
MESABALANCING 06-06-2005 07:26 AM
CMI is making some headers for it
lloyd 06-06-2005 05:45 PM
Here is a company in New Zeland that has marine manifolds for the LS1.http://www.waspaust.co.nz/Chev6.htm
FOUNTAINATLAST 06-07-2005 01:44 AM
With that lite motor producing some big block numbers that boat should be pretty impressive!!!
