500hp opperating # >
500hp opperating #
500hp opperating #
Old 06-13-2005 | 11:40 AM
Wild's Avatar
Default 500hp opperating #
what are the temps and etc for 500hps
Idle
Water Temp
Water Pressure
Oil Temp
Oil Pressure
5000 rmps
Water temp
Water Pressure
Oil Temp
Oil Pressure
Randy Wild
Wild is offline
Old 06-13-2005 | 03:07 PM
Ran-Dom 32's Avatar
Default Re: 500hp opperating #
Idle
Water Temp
Water Pressure
Oil Temp
Oil Pressure
5000 rmps
Water temp
Water Pressure
Oil Temp
Oil Pressure
Randy Wild
900 rpm out of gear 750 in gear
water temp 140-150
25lbs water pres. @ 3000
oil temp 190-200
oil pres. 50-60 @ 3000 30 @ idle
Ran-Dom 32 is offline
Old 06-14-2005 | 04:45 PM
Mudball's Avatar
1999 HP500 carb w/crossover, thermostat and relief valve, so different cooling setup, but similar to stock results:
Idle 700rpm (after warm up and idle for a while):
Water temp: 140
Pressure: 2-3
Oil Temp: 180
Oil Pressure: 25
5000 rpm:
Water temp: 145-150
Pressure: 25psi (relief valve open)
Oil temp: 200-220 (depends on time at this rpm)
Oil pressure: 55
Kent
Mudball is offline
BLOWN85
26
09-12-2007 08:33 PM
BLOWN85
Velocity
0
09-09-2007 09:42 PM
sleek1
8
09-01-2007 05:18 AM
LAKESIDE RESTORATIONS
New Products and Member Discounts
0
07-15-2007 09:36 AM
speediseverything
26
06-08-2007 02:14 PM
