-   -   what causes engine steam (https://www.offshoreonly.com/forums/general-q/105953-what-causes-engine-steam.html)
PARMENTIER123 06-20-2005 11:22 AM
I've been told head gasket or advanced timing can cause this..i'm sure it would but always????............they are 350 mags...it only happens when i just completed a 5000 rpm run........common sense sais, the exhaust is hot and its steaming when cool water hits it. I've always believed this till my buddies 30 searay w/inbds only steamed from one engine..............anyone have any input or opinions on this.... ............thanks
Shore Thing 06-20-2005 03:20 PM
Re: what causes engine steam
I don't know, but mine always steams at least a little. like you said, after WOT, the steam is increased. I don't know if this is a problem or not, but so far i haven't had any related problems.
Reed Jensen 06-20-2005 05:03 PM
Hot spots in the head will cause the water to "spot boil". The engine temp will be normal.... but the hot spots will cause a little steam to come out the exhaust. You don't see this on a closed presurized system because the added pressure raises the boiling point.
