-   -   454 mag mpi upgrade (https://www.offshoreonly.com/forums/general-q/106483-454-mag-mpi-upgrade.html)
dsandman6 06-27-2005 07:53 PM
454 mag mpi upgrade
Im pulling the motor to fix a cracked piston want to upgrade while its out does any body know best set up im not going crazy with it but everybody tells me i can do a heads and cam change that will wake the motor up thanks Randy
Vinny P 06-27-2005 08:13 PM
Re: 454 mag mpi upgrade
You can't do any changes like that without remapping the ECU.
dsandman6 06-27-2005 08:29 PM
Yea i thought I would have to do that just thought there might be a certain set up someone had tried
Madmax 06-27-2005 09:22 PM
Don't bother unless you are going to ditch the MPI. There are a few on here that have tried it, and it wasn't worth the $$. The MPI settup really limits the hp that you can make.
Possibly sell your motor and upgrade to a 454 mag or 502? Just my 2 cents worth.... :drink:
dsandman6 06-28-2005 06:44 PM
Thats just the answer i needed to make my decision Thanks Randy
Chase910 06-28-2005 07:29 PM
If you have the 454MAG version, you can make about another 100hp or so with modded stock heads, cam, exhaust and ecu upgrade. There are a few vendors who will sell you the whole package.
Tyler Crockett, located in Michigan, 810-324-2720 came up with this upgrade several years ago for the 502mag, and it applies to the 454mag as well. Its a dyno proven package. You can send them the engine, or they can send you the parts.
Teague also has a kit as well.
