Re: More carb questions????
Still going at it!! I got a small amount of gas from the vacuum line when I removed the gage is that normal??? Also I bought this used so I have no manual / I see that it has a idle easy screw where should that be set to / I need to get back to base.
Kmiller, you said you put a 6.5 power valve in. you wrote you had 7.5-8.5 vaccum. if thats the case you should have a 3.5 power valve. you take your vac. reading and split it in half ,this a general rule of thumb.B.Miller
Thats what I thought I will try to get more vacume first / then I will get a different powervalve........
I could not find my idle-eze screw untill this....... I pulled the carb base off and found the idle-eze screw but the hole was never drilled out under the stud..... Well I drilled it out and clean the carb up, looks like the base plate was newer then the carb body, also the Idle-Eze was all the way in and the primary transfer slot was around 3/16 long, re-adjusted and start over....... Might have been my vacuum problem also?? Well thanks for all the help
Kyle Miller SCS, M.I. |
| All times are GMT -5. The time now is 07:49 PM. |
