oil pressure problems from stock hardware >
Old 04-26-2021 | 06:03 PM
  #191
articfriends's Avatar
Originally Posted by Tractionless
Thanks I'll have to check into the location of the block adapter. I'm guessing this is where the oil filter would be in an automotive application, bottom side?
I have low oil pressure on a OE 416 hr. '96 7.4 lx mpi. Aside from a bad dash mount oil pressure gauge I don't see why the pressure would be low. I'm hoping switching the valve would help with the pressure issue.
A 11 lb autiomotive valve can only open and allow unfiltered, uncooled oil to bypass the cooler and filter resulting in engine damage if its original with standard volume oil pump, unless bypass is hung open, i doubt its your problem though. Im of the understanding mercruiser used the stiffer bypass valves but not 100% sure. The lines, cooler and bypass were sized appropriately from factory for stock clearances and standard oil pump and usually work for hundreds of hours. Now, if someone put a high volume oil pump in, then it could be bypassing the cooler and filter, smitty
articfriends is offline
Old 04-29-2021 | 04:58 PM
  #192
Gotcha, I'll check with another oil pressure gauge first as I'm lost as to what else could cause the low pressure, aside from what you mentioned.
Tractionless is offline
Old 04-11-2026 | 03:58 PM
  #193
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Back to the top. Great thread! This saved me from going from a bad situation (not of my doing) to a much worse one. I remember reading this back when it was first posted and decided go over it again recently. My engine started life as an HP500 and I see it still has the bypass valve on the outer side of the oil filter pad. Being I'm now going with a Melling 10778 I will remove and block with a Melling 13/16 plug and go with a larger oil cooler as well as a high capacity filter pad, lines and filter mount from Hardin Marine thanks to the information found in this thread. One more question though, being I have a choice between an HP4 or HP6 style oil filter, which would be the better option for a blown 509 making 855hp. Sincere thank you to Articfriends and all who contributed here.
the deep is offline
Old 04-12-2026 | 05:01 AM
  #194
Originally Posted by 29scarab
That brings up another question. I have 502mpi with a whipplecharger. Live in Texas on the gul coast. We average 90 plus on daily basis. I know the water temp is also warm. What is safe oil temp for an engine in this enviroment?
210-220°f is optimal...so it has enough thermal capacity to cool the engines parts...mainly the springs.
Tartilla is offline
Old 04-12-2026 | 07:59 PM
  #195
Rookie's Avatar
Standard HP4 is what I would use. We ran the HP6 on the race boat, but for a recreation boat I would just run the HP4. They are readily available anywhere. You never know when you might need to change the oil. Crack in the oil cooler, stuck injector, or bowl seat not shutting off.
Rookie is offline
Old 04-12-2026 | 09:22 PM
  #196
the deep's Avatar
Fast Singles Club
Thank you Rookie. Much appreciated.
the deep is offline
Old 04-13-2026 | 12:18 AM
  #197
Don't forget you can run 2x oil filters in parallel. I'm not a fan of the 62 micron ultra flow racing filters. Maybe as a first state, but we don't tear down our engines every few runs.
Lots of good filtration options.
Having a personal experiemce of spinning a main bearing from oil bypass...I don't like it at all. Bypass to oilpan ok of course...but not bypass filtration.
Check out David Vizards newer vids on setting up the oil pump and cleanking up the oil flow path. Worth the watch..and would help you setup your new oil pump.
Tartilla is offline
Old 04-13-2026 | 09:10 AM
  #198
the deep's Avatar
Fast Singles Club
What would be the best option for a high flow/good filtration Hp4 style filter? I would imagine, like everything else, there is a reasonable compromise?
the deep is offline
Old 04-13-2026 | 11:23 AM
  #199
Just to clarify as I saw some conflicting information in this long thread.
The 30psi bypass valve is part# 25161284.
The 11psi bypass valve is part# 25013759
87MirageIntruder is offline
jhoward
07-08-2007 09:43 AM
tjsmk8
11
05-28-2007 09:40 AM
BAYVILLAS
2
07-26-2006 11:10 PM
Revd Up
6
07-06-2006 11:32 PM
FOUNTAINFAMILY
6
10-25-2005 06:27 PM
