-   -   drive oil leaking inside bilge??? (https://www.offshoreonly.com/forums/general-q/106684-drive-oil-leaking-inside-bilge.html)
5PMSMWHR 06-29-2005 06:19 PM
28 ft donzi twin 350 mags, bravo one drives, went out last week and greeted by beeping when I pulled back to dock. Marine guy said most likely impellers so replaced both. just got boat back and notice drive oil leaking down the back of the port drive inside the engine compartment. Thoughts as to what I'm looking at here? Thanks in advance,
rssteiny 06-29-2005 07:03 PM
Re: drive oil leaking inside bilge???
Just Had The Same Problem Runnin In A Poker Run And Started Beaping Found The 1 Drive Bottle Was Empty Pulled It Off Found Back Of Bottle Wet From Cap Down, I Found That The Rubber Gasket In The Cap Was Missing When Running Hard It Builds Pressure In Bottle And Was Pushing Out The Cap Because The Seal Was Missing.
5PMSMWHR 06-29-2005 08:28 PM
thanks for the response but I'm seeing the oil where the drive and engine connect on the inside of the engine compartment. ???????????????
US1 Fountain 06-29-2005 08:33 PM
Check the hose connection at the transom plate. It's just a simple slip on with a push button lever to hold it on. They are somewhat loose when installed and rely on the o-ring to seal. Right under the water inlet hose, fairly easy to reach and diconnect.
tcelano 06-29-2005 10:51 PM
If you are seeing oil draining out from the u-joint bellows, your drive's upper gearcase oil seal is shot. That's the most likely culprit if you are seeing oil as you describe. The beeping you heard was most likely the low drive oil warning. To fix it, the drive needs to come off, but that's pretty quick and easy, and you can have your motor alignment checked at the same time. If the drive has been run low on oil, you could have other issues in there, but hopefully this hasn't been going on for long enough to cause a major problem.
mr_velocity 06-30-2005 10:55 AM
Yup upper drive seal, probably need to replace the shaft was well.
Wobble 06-30-2005 11:07 AM
Make sure you regrease the bearing. The drive oil could have flushed the grease out.
5PMSMWHR 07-14-2005 01:21 PM
And the winner is the upper gear case oil seal. Thanks for all the the help. Fixed in time for what should be an awesome weekend on Lake Ontario.
Wobble 07-14-2005 01:29 PM
Thanks for the update.
Enjoy a safe boating weekend, I plan to.
