-   -   Speedo Pickup (https://www.offshoreonly.com/forums/general-q/106806-speedo-pickup.html)
velocitypwrbtr 07-01-2005 08:53 AM
Speedo Pickup
Would a pickup for a speedometer reduce your WOT speed?
Sean H 07-01-2005 09:05 AM
Re: Speedo Pickup
in theory, yes, it is causing drag... is it noticeable? probably not...
Mr Gadgets 07-01-2005 09:19 AM
Re: Speedo Pickup
Unless the hole it digs in the water gets large enough to effect the water to the prop.. then yes it can be noticable. GPS has solved that little problem..
