-   -   engine miss-firing (https://www.offshoreonly.com/forums/general-q/106888-engine-miss-firing.html)
dennis obyrne 07-03-2005 09:42 AM
engine miss-firing
The engine will rev up fine, then I put it into gear and it will miss and back fire. I changed the plugs,the fuel filter and added dry gas, it is still happening
Griff 07-03-2005 12:44 PM
Re: engine miss-firing
What engine???
I would also change the cap and rotor and check the timing.
mr_velocity 07-03-2005 01:10 PM
just putting it into gear at idle when when you try and get on it. Could be a lean backfire and not really missing. Just went through the same thing, sure acted like ignition but it was a lean backfire, rebuilt the carb and found a little snot of rtv in it.
