-   -   Trim limit Bravo XR (https://www.offshoreonly.com/forums/general-q/106922-trim-limit-bravo-xr.html)
migpilot 07-04-2005 09:51 AM
Trim limit Bravo XR
Can you damage a bravo XR drive coupler or U-joint by starting it (rare moment of confusion and no power transmitted) with the trim all off the way up? I had heard that limit sleeves provide some protection in the XR. Any one know for sure.
TINO160 07-04-2005 10:20 AM
Re: Trim limit Bravo XR
Yep,you Can Hurt The U-joint And Coulper In Any Bravo Drive Running It With The Drive Up.even In Neautral The U-joint Turns.
migpilot 07-05-2005 07:47 AM
I understand that, however I was looking for some input on whether the trim limit sleeves in the trim cylinders provide protection for the beefier u-joints and input shaft in the XR.
Scarab28 07-08-2005 06:39 AM
The trim extension is limited from 27 1/16 to 26 7/16 inches to protect the U-joints. See merc bulletin no 2000-8.
Tilt limit kit part # 15768A3.
