-   -   ignition not advancing - help! (https://www.offshoreonly.com/forums/general-q/107306-ignition-not-advancing-help.html)
ECeptor 07-08-2005 10:14 PM
The timing light just proved my 1989 330hp 454 with Thunderbolt IV (4) ignition is not advancing as the rpm's go up.
From what I've learned so far, my options are:
1) buy a new advance module - $320 from local dealer, week to get
2) hope to find a used module on ebay - $??? available ???
3) buy whole new system through Summitt - ~$250
4) hope my hotboat buddies can come through for me with a better option that the ones above!
So, am I right in thinking it's the advance module that has gone south? I've triple check all the wiring vs the manual and everything there is good. I have no idea how old the module is.
Advice, thoughts, opinions?
scarrab30 07-09-2005 08:58 AM
Re: ignition not advancing - help!
I put an MSD in mine. Its easier to get parts for amd does just as good a job as thunderbolt. I put mine in 6 years ago and am very satisfied. I put in a billet distributor,msd box,blaster coil.
mtm 07-09-2005 09:38 AM
ECeptor
Check all the grounds for the box and clean all connections .
Or go with the Crane HI6 M
ratman 07-09-2005 10:17 PM
cranes hi 6 is a great ign system
ECeptor 07-09-2005 10:51 PM
Originally Posted by mtm
ECeptor
I checked the wiring to insure everything was hooked up and tight, but didn't take every connection loose, clean then re-connect.
I'll try that tomorrow on the off chance it fixes the problem.
Gary Anderson 07-11-2005 08:35 AM
Just replace the module. The Tbolt are pretty reliable. Parts availability shouldn't be a problem.
BTW, Doller can probably get you one cheaper and faster than your dealer.
And you might want to check on that Summit price. You'll need a MSD marine distributor AND and MSD box if you change over.
mopower 07-11-2005 10:49 AM
Got it ALL over MSD :cool:
ECeptor 07-11-2005 09:18 PM
I just bought a new module off of ebay for $125. That's much cheaper than a complete system and much cheaper than the $337 the local dealer wanted to charge.
I hope it make it here for the weekend!!!
