-   -   Broken ears on Bravo I props anyone? (https://www.offshoreonly.com/forums/general-q/107472-broken-ears-bravo-i-props-anyone.html)
Sonicdriver 07-11-2005 08:18 PM
My friend has a 33 Baja Outlaw w/496's on Bravo's. He's running the Bravo I prop i'm guessing about 27 pitch We were on a local poker run yesterday when he broke his 5th prop in 2 years. All of the props have come on the starboard side. Each prop is missing 1 blade and all 5 props are broken in the EXACT same place. By this I mean they are all broken next to the Bravo I stamp.
Any suggestions on what this would be?
P.S. The drives are turning out.
FOUNTAINATLAST 07-12-2005 12:14 AM
Re: Broken ears on Bravo I props anyone?
Seems to be common, I've seen a few broken props myself with no rime or reason??? :rolleyes:
Strip Poker 388 07-12-2005 12:52 AM
do they look like this ??? :eek:
http://www.offshoreonly.com/forums/s...ighlight=props
Airpacker 07-12-2005 08:32 AM
I can tell you that is common place on single engine cats. My buddy has lost 3 in 2 seasons. Bad Mercury, Bad.
throttleup 07-15-2005 09:26 AM
A good place to start when you have a problem like this is to llok in front of hte drives and props. Is there anything that could disturb the water flow to the drive/prop?
Another possible cause is the height of the drives. If they are mounted too high the constant prop slapping can lead to broekn blades.
What kind of performance numbers is the boat getting, WOT speed, WOT rpm, and drive gear ratio? An excessive slip could indicate a drive mounted too high.
Matt
Cord 07-15-2005 12:08 PM
My guess would be that for some reason, that drive is cavitatingor surfacing slightly when he is at speed.
