-   -   would this motor work in my boat? (https://www.offshoreonly.com/forums/general-q/107531-would-motor-work-my-boat.html)
tahoeguy318 07-12-2005 02:41 PM
Would this motor be acceptable to run in my swc formula?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
I am lookin for a replacemnt for my 350 mag that spun a bearing. what would I Have to do it?
Harry
birdog 07-12-2005 02:49 PM
Re: would this motor work in my boat?
Not knowing the Comp ratio & the cam grind it's hard to say.
I dont see anything real special about it...Scat crank...stock rods..Hyper pistons...smallish valves....Others will chime in that know more than me..
tahoeguy318 07-12-2005 03:01 PM
so at most maybe a cam change anything else?
jspeeddemon 07-12-2005 03:14 PM
Assuming that the compression is 9.5:1 or less, the cam can easily be changed to a 112 or 114 LSA. Then it should work well in your boat. Have you also looked on, Greenwood chevy or one of several GM dealers who offer deals thought the ineternet, for a 350 Mag?
tahoeguy318 07-12-2005 03:53 PM
no I have not...that price looks good though? I have been looking to get a little more speed out of the 21' formula also so this might be the place to start! plus the colors match my boat lol
cstraub 07-12-2005 04:29 PM
383's are usually external balance. Your 350 is internal so it will have to have a new flywheel. Freeze plugs need to be brass also. Steel plugs will corrode in no time.
Chris
onesickpantera 07-12-2005 05:50 PM
HP looks a little low for a 383?
mike11 07-12-2005 09:13 PM
Tahoe what are you looking to spend I can build you whatever you would like. MIke
tahoeguy318 07-13-2005 07:59 AM
I am not sure what I am looking to spend...right now I have a 1989 350 magnum with vortec heads and an edelbrock air gap intake unfortunatly with a spun bearing :mad:
I wanted to upgrade a little and the price of that motor looked good...what can you do for me?
Harry
tahoeguy318 07-13-2005 08:01 AM
does anyone know what heads those are? I have vortec heads and an airgap manifold will they produce more hp than that one? thanks
Stingray69 07-13-2005 09:42 AM
Look at these two places.
http://www.1800runsnew.com/used.html
http://www.perfprotech.com/home/newblock_table.htm
tahoeguy318 07-13-2005 11:38 AM
some decent prices..what do you think of this? http://motorworksengines.theshoppe.c...ne_engine.html
