Help - Reverse problem - Outdrive guys
I had to replace the driveshaft due to U-joints exploding. After puting it all back together, I now can shift to neutral and forward fine. When I shift to reverse, it keeps popping in and out of gear.
I disconnected the shift cable and maually shifted it, it does the same thing. What should I check next. |
Re: Help - Reverse problem - Outdrive guys
Why does it pop in and out of reverse - is it an adjustment or blown clutch?
WILL BE GLAD TO TRY AND HELP U OUT BUT FIRST NEED TO KNOW WHAT KIND OF DRIVE....MERC??? ALPHA BRAVO ECT
JOE AMERICAN PERFORMANCE MARINE [email protected] |
'89 bravo drive
When the U joints exploded it may have streched the shift cable that goes to the drive.
I replaced the entire transom assembly with a TA from an HP500 so it is a newer shift cable.
| All times are GMT -5. The time now is 03:40 PM. |
