-   -   what are you running in your bw trans? (https://www.offshoreonly.com/forums/general-q/108159-what-you-running-your-bw-trans.html)
Pwrbt33 07-28-2005 07:23 AM
Re: what are you running in your bw trans?
While rebuilding transmissions in our shop I use type "F". It seems to be easier on the clutches and bearings. Plus if something freaky was to happen, you can get it anywhere.
John :D
Lmarth 07-28-2005 11:10 AM
Brian-Everything I mentioned you can buy at BoatUS. The drill mounted pump is a "Jabsco Sef-Priming Electric Drill Pump Kit". You reverse it by reversing your drill. The kit consists of the pump, a large ID hose, a small ID hose and some adaptors. I bought a couple and recall them costing about $25. The reversible oil change pump I use is also an ITT Jabsco unit with a 10qt bucket. This pump is rated @ 10amps. I've also got a Shurflo with a smaller bucket that's rated @ 7.5amps. Personal preference, but I prefer the Jabsco. From what I've heard, the best is the Reverso which sells for about $230 compared to the $140 or so for the Jabsco. For me, it's a lot cheaper to change fluids,filters etc. than to pull motors, transmissions,etc. Whats a couple bucks for 4 quarts of ATF? Just my $.02....Lou
