-   -   any riggers care to give some FREE advice? (https://www.offshoreonly.com/forums/general-q/108248-any-riggers-care-give-some-free-advice.html)
ratman 07-21-2005 08:29 PM
need some help. i have a clearance issue between my two center pipes and need a fix and any suggestions would be too kind. thx, ratman
Mr Gadgets 07-21-2005 10:52 PM
Re: any riggers care to give some FREE advice?
ratman... at what point do they touch.. Could you tip the top in and gain clearance or is it right at the bend in the tubes? If you made a wedge you could tip them in some.. That might help?? How about a pic with the two side by side.
HARDCORE A/O 07-21-2005 11:14 PM
If they're touching at the tops, maybe you could get some 3/4 " exhaust header/manifold spacers from CP Performance and angle-mill them and install them on one or both of the center headers so they kick the tops outward away from each other?
HiPerf2000 07-22-2005 01:13 AM
it all depends where the clearence issue is......bottom or top ????
Like mentioned above, if the problem is high, you maybe able to space out the bottoms.
