-   -   Gen. keeps stalling out (https://www.offshoreonly.com/forums/general-q/108708-gen-keeps-stalling-out.html)
CAP071 07-28-2005 10:12 AM
My Gen stalls out after about 1 min. It restarts right away but stalls out again after a min.?? I don't put any load on it I just start it and it starts right up it just won't stay running. :cool:
HiPerf2000 07-28-2005 11:23 AM
Re: Gen. keeps stalling out
Check to see where it is drawing the fuel from the tank. There may be a valve there that is closed. Then check the filter on the genset. Seems like a fuel problem.
Gary Anderson 07-28-2005 01:39 PM
Generators generally have a safety shut-off mechanism for overspeed, low oil pressure, hi temp, and some other conditions. If it dies because of loss of spark, this may be your problem. Check to see if any of these are a problem. If not, disconnect the grounded kill wire from the distributor or magneto. You might need to check your wiring diagram for this. If it runs then, it's probably a relay in the shut off circuit.
If it dies from lack of fuel, check filter, pump, carb, etc.
Pwrbt33 07-28-2005 01:48 PM
Ditto ... :D
Gary Anderson 07-28-2005 01:51 PM
A man of few words. :p
Originally Posted by Pwrbt33
Ditto ... :D
Magicfloat 07-28-2005 06:19 PM
Most of the time,no water. Is water flowing thru the thru hull fitting? If the boat has been on a trailer or in dry storage, it may have lost its prime,an easy fix. Or the impeller may have failed,also an easy fix.
Ted G 07-28-2005 08:08 PM
Also check the oil level-will shut off if it's a little low.
CAP071 07-31-2005 09:03 PM
Any mail order places where I can order a Tune up kit? It's a Kohler 5E genset
