-   -   Fuel lines (https://www.offshoreonly.com/forums/general-q/108845-fuel-lines.html)
ofshore 07-30-2005 08:49 AM
Fuel lines
What do you guys use for your fuel lines coming in and out of the fuel pump? Mine are hard copper tubing and I'd like to get something flexible so if I change something I don't have to make new lines.
Payton 07-30-2005 10:16 AM
Re: Fuel lines
Summit sells a flexable SS kit with all the fittings you need, from a couple of different manufacturers. Just cut to the length you need and install the ends. Be sure to use some sort of lubs to get the fittings onto the lines, it is much, much much easier.
ofshore 07-31-2005 09:30 PM
Re: Fuel lines
thanks guys I'll check out summit and see what they have.
