-   -   leaking oil (https://www.offshoreonly.com/forums/general-q/108942-leaking-oil.html)
johnnyboatman 07-31-2005 06:59 PM
leaking oil
looks like the frt of the intake, the middle of the engine is dry, the frt under the pan is dry looks like is running out the ffrt and down the sides has this happened to any one else.
formula31 07-31-2005 07:07 PM
Re: leaking oil
Mee, havent found it yet either, not too much blow by, seems to be worse at wot though, I almost think mine is front of the oil pan. Leak is way worse when its rough.
johnnyboatman 07-31-2005 07:52 PM
Re: leaking oil
no blow by here, im going to clean with brake cleaner and silicone it till winter and tear it down and find it for sure.
