-   -   beeping alarm won't shut off (https://www.offshoreonly.com/forums/general-q/108971-beeping-alarm-wont-shut-off.html)
thanks2ed 07-31-2005 10:26 PM
I have a 1989 20' Cararra with a 220 Laser XRI (EFI)(Mercury) and can not figure out why the beeping alarm won't shut off. The oil level is good the fuel is good. Looking for a list of reasons why the alarm will sound. :mad: Does any one have any idea's where to start? I also have been looking for a manual. Thankyou in advance
GOODT 07-31-2005 10:37 PM
Re: beeping alarm won't shut off
Did You Check Oil Tank On Motor????
HiPerf2000 08-01-2005 08:05 AM
Outdrive oil resivour
GOODT 08-01-2005 08:11 AM
yes
Bill272 08-01-2005 08:43 AM
I had an alarm this weekend and sure enough it was the drive oil reservior. It's a common cause for the alarm going off when everything else seems normal.
Dock Rat 08-07-2005 02:30 PM
I had a similar problem and it was a faulty depth gage that had an alarm. It would just start beeping and saying I was in a foot of water, but in reality I was in 30 feet. I just turned off the depth alarm :) Not sure if yours is the same problem but maybe worth checking out.
drypipetiger 08-07-2005 02:56 PM
If your running hard and slow down quickly your oil pressure will sometimes drop below the alarm range.
MarineShopInc 08-07-2005 03:12 PM
oil pump gear failure, oil tank sender bad, or oil alarm module is is bad
