-   -   emergency engine hatch access? (https://www.offshoreonly.com/forums/general-q/109454-emergency-engine-hatch-access.html)
342boss 08-07-2005 11:17 AM
The batteries on my 1999 342 Boss are dead and the engine hatch is closed. Anyone know if there is an emergency access hatch so I can get at the batteries to charge?
Thanks!
cuda 08-07-2005 11:46 AM
Re: emergency engine hatch access?
I'm not sure on your boat. Some are made where you can lift the hatch manually far enought to pull a pin to disconect the hatch, others have a set of leads to the battery under the rear seat. Seems my buddy had the leads in his Baja.
Pwrbt33 08-07-2005 01:25 PM
Do you have a cigarette lighter socket on board? Get an adapter of some sorts and cut the opposite end off, plug the good end into the cigarette lighter and the wires to the appropriate side of a jumper boost back, extra battery or a battery charger. Then raise the hatch.
John :D
342boss 08-07-2005 05:41 PM
Thanks - appreciate the help. This is what I did and the problem was solved easily.
Pwrbt33 08-07-2005 09:39 PM
Good to hear !!!! :evilb:
US1 Fountain 08-07-2005 10:28 PM
Now think of a plan if the lift were to go bad.
32 thunder 08-07-2005 11:01 PM
Shorepower Plug In If You Have It!!
jdnca1 08-08-2005 08:34 AM
Pull the hinge pins and lift it manually from behind, then squeeze in and pull the pin on the acuator. (assuming you have access to the hinge pins)
cuda 08-08-2005 08:41 AM
Which way did you do it?
dtsquest 08-08-2005 05:41 PM
On my Powerquest I can lift the hatch manually if the battery is disconnected. I figured that out while removing the batteries for winter storgae. Just get your hands under the hatch, and lift.
