-   -   496 oil in coolant (https://www.offshoreonly.com/forums/general-q/109501-496-oil-coolant.html)
betitbig 08-08-2005 12:09 AM
496 oil in coolant
I have a 496mag HO whippled, with less than 10 hours on it and I keep getting oil in the coolant. I have no reverse problem such as coolant or water in the oil. I have pressure tested the coolant system for any leaks and only loose 2lbs of pressure in an hour, so what gives?
Anyone ever have this problem or hear of it?
Any ideas on what would cause this to happen?
betitbig 08-08-2005 12:46 PM
Re: 496 oil in coolant
Could it be a problem with the heat exchanger?
betitbig 08-08-2005 01:48 PM
Or could it be a problem with the oil cooler?
Hydrocruiser 08-08-2005 04:49 PM
Are you getting coolant in the oil?
Even small amounts can destroy the engine.
Time to send an oil sample to Blackstone Labs.
GOODT 08-08-2005 06:15 PM
Sounds Like A Head Gasket
Pwrbt33 08-08-2005 06:50 PM
Ditto on the head gasket. :D
Kokopelli 08-12-2005 01:29 AM
Steve,
Don't think it its the heat exchanger or oil cooler - I beleive both are cooled by sea/lake water not coolant. I too would lean towards head gasket - Were the heads torqued correctly? Their is a very specific procedure to torquing the 496 heads I beleive. Check with Peto or GT. You don't want coolant in your oil, it's bad news.
crayolacrazy 08-12-2005 07:45 PM
I noticed my coolant bottle getting dark after getting it real hot .In my case its sut. I removed the tank cleaned it 5weeks ago now I have to do the other side I hope you have the same issue.I also run 496 s with whipples call me at 412 7810881
