-   -   Will oil in transom cause rot or not? (https://www.offshoreonly.com/forums/general-q/109707-will-oil-transom-cause-rot-not.html)
phughes69 08-10-2005 12:00 AM
When I was getting my boat ready for the year last year I had to bleed the trim tabs because one of them would not hold pressure. I found oil coming out thru the top of the transom on the inside. One of the hydraulic transfer tubes (Aluminum) for the trim tabs ( K planes) corroded away and was leaking oil into the transom. Would this cause the transom to rot? What should I do about the transom? I replaced the tubes with a stainless one and the holes that did not have the coroded tubes were dry.
Cord 08-10-2005 05:34 AM
Re: Will oil in transom cause rot or not?
If oil got in there, then moisture can too. Where wood and moisture come in contact, the wood will rot.
