Help Needed With Warning Buzzer
Hi,im New To All This And Would Like Some Advice Please.
My Warning Buzzer Has Started To Go Off Even When Left For A Day It Still Sounds When Turning The Key,my Merc 2 Stroke Outboard Does Not Get Hot To Touch Even After Running At 60mph For Half An Hour,and Is Pumping Water Out Fine,the Buzzer Still Sounds When You Disconect The Earth From The Senders So Im Really Puzzled,i Would Really Like Some Advice As I Dont Want To Do Any Damage By Running With The Buzzer On,could It Be A Buzzer Fault?? Thanks Jamie,uk |
Re: Help Needed With Warning Buzzer
do you have remote oil tank?????
Hi,
No Its Been Removed To Run Pre-mix. Thanks, Jamie.uk |
what yr is the motor and does it have a oil tank mounted on the motor????
hi,approx year is 93 ,no oil tank attached as its been converted to pre mix,just got back from taking her out and shes running fine,no overheating at all,steering arm snapped on motor leg so it did a sharp turn at 50mph,quite exciting!!!
Sounds Like Fun!!!!! Glad To Hear Your Ok Check To See If The Wiring From The Old Tank May Be Grounding Out For The Most Part The Only Things That Will Set Off That Buzzer Are Overheat Or Low Oil!!!!
cheers mate,i will look at that tomorrow after welding back on bracket!!
im ok,just ended up sitting on my passengers lap!! still great fun and like riding a horse youve just gotta get back on,yee ha !!! :D |
