-   -   Prop Shaft Sizes Bravo 1 - XR (https://www.offshoreonly.com/forums/general-q/109823-prop-shaft-sizes-bravo-1-xr.html)
Shah Mat 08-11-2005 05:54 AM
Is the XR and a Bravo 1 the same shaft? I have a prop for sale a prospective buyer has a XR drive with a 1 1/4" shaft. The prop came from my Bravo. Will it work?
GOODT 08-11-2005 06:15 AM
Re: Prop Shaft Sizes Bravo 1 - XR
1 Attachment(s)
No! Different Size
Pwrbt33 08-11-2005 06:17 AM
If your prop is a Mercury prop, it should be able to change the hub. If its someone elses like Haring or Hydramotive, no.
John S. :D
Shah Mat 08-11-2005 06:24 AM
Unfortunately for me and him, it's is a Hydro.
The interchangeable hub you speak of, is that called a Mercury flo-torq hub?
GOODT 08-11-2005 06:27 AM
Yes It Is, Its Avalible As A Plasic Or A Solid Hub
Pwrbt33 08-11-2005 06:28 AM
Mercury has 2 types of hubs it uses alot, thaer are more but usually under 300 hp they can use a flow torque hub. Over that they use a better steel hub with rubber linings.
John S. :D
throttleup 08-11-2005 06:30 AM
If the prop is a Hydromotive and was manufactured in the past 18 months it should have the square bore, Flo Torque 2 compatible. If it was manufactured more than 18 months ago the hub is probably welded in with the 15 spline hub. There is a remote possibility it may have a rubber hub pressed in to it, in which case the rubber hub can be pressed out.
The welded 15 spline hub can be changed to the larger XR 1 1/4" shaft. The old hub is machined out and the new one is welded in.
If you have any questions please call. The cost is about $150 and that includes the new hub.
Matt
GOODT 08-11-2005 06:34 AM
MATT,
Thanks llearn somthing new every day, I didnt know that!!!!
Shah Mat 08-11-2005 08:14 AM
Thanks for the info guys. It is an older 26p Hydromotive with a welded hub.
I had seen a prop with a square hole in it, but wasn't sure if that was what they call Mercury flo-torq hub.
