-   -   525SC lifters and valve springs (https://www.offshoreonly.com/forums/general-q/109882-525sc-lifters-valve-springs.html)
dykstra 08-11-2005 06:33 PM
Any suggestions for lifters and valve springs. I am ordering the stock cam. Crane#132561.
dykstra 08-12-2005 09:29 AM
Re: 525SC lifters and valve springs
ttt
PatriYacht 08-12-2005 10:57 AM
Just order the stuff that Crane reccomends. I had the same cam in my Cyclone 400s for 11 years and 600+ hours with no problems whatsoever. Be careful at cam breakin time. DO NOT IDLE FOR THE FIRST 20 MINUTES.
MESABALANCING 08-12-2005 02:25 PM
I agree to ensure your self the breakin is going right crack the valve covers loose and make sure your pushrods are all turning do this by marking the pushrod with white marker if all the pushrods are turning it will last for ever if you have any that don't turn stop because it will scrub the lobe and you'll have to start all over again. Good luck to you.
dykstra 08-13-2005 08:29 AM
Thanks for the info. Crane recommends #99277-16.
