Searching - Used 502 out there? >
Old 08-10-2005, 03:54 PM
Charter Member #300
Shooter's Avatar
Default Searching - Used 502 out there?
Anyone have a (or know someone) with a used 502? Please let me know....
thanx
Shooter is offline
Old 08-10-2005, 04:35 PM
wkd1's Avatar
Default Re: Searching - Used 502 out there?
thanx
I do but its in california.......
wkd1 is offline
Old 08-10-2005, 06:33 PM
Charter Member #300
Shooter's Avatar
just for the helluvit what are you asking for it?
Shooter is offline
Old 08-10-2005, 09:09 PM
I hate the winter!!
Vinny P's Avatar
I have a 454 Magnum MPI if interested.
Vinny P is offline
Old 08-10-2005, 09:58 PM
Smile Re: Searching - Used 502 out there?
I've heard there are a few on Ebay lately?
Ray @ Raylar
Raylar is offline
Old 08-10-2005, 11:00 PM
wkd1's Avatar
$6000.00
MSD complete marine system
Deluxe Ignition Package
"Deluxe" MSD / Hardin Ignition Package - Chevy V8
(1) Billet Marine Distributor
(1) MSD 6-M Series Multi-Spark Ignition Control Box
(1) High Vibration Coil
(1) Soft Touch Ignition Rev Control
(1) Deluxe Polished Stainless Steel Cylinder Head Mounting Bracket
(1) Custom Fit 8 MM Heli-core Spark Plug Wire Set
(1) Red Billet dist. hold down and stud
The Motor,Long Block
Gen VI four bolt main block, with forged pistons, forged 4340 steel connecting rods with 7/16" bolts, a 1053 forged steel crankshaft , Blue printed high volume oil pump , Dually 10 qrt. with windage tray and scrapper , Comp Cams XR300 Hr Hyd. roller cam shaft Exh. lift .254 / .580 Int. lift .248 / 560 , roller Lifters ,Comp Cams SST roller rockers, Comp cams stud girdeles, pushrods Complete valve train . Comp Cams true roller timing set ,Edelbrock 6045 alum heads ported and polished by R&R Machine In Napa Ca,Stainless steel 2.19" intake and 1.88" Polished alum. timing cover , polished alum. crank pulley , SFI approved flex plate.Aluminum exhaust with center risers,Edelbrock single plunum manifold.
wkd1 is offline
Old 08-10-2005, 11:36 PM
vandeano's Avatar
Originally Posted by wkd1
$6000.00
If I only knew this 2 months ago....where in California? Any where near Manhattan Beach?
vandeano is offline
Old 08-10-2005, 11:43 PM
wkd1's Avatar
Northern California...Near Napa
wkd1 is offline
Old 08-11-2005, 12:23 AM
Ports's Avatar
got one on my lift, but its surrounded by a boat. heck you might as well buy the whole package
Ports is offline
Old 08-11-2005, 07:55 AM
Charter Member #300
Shooter's Avatar
looking for stock only. Hey if that were the case I got two for sale with the boat. Ebay gives me the heebee geebees. I buy and sell lots of small computer stuff. I'd be afraid of a ripoff.
Shooter is offline
Quick Reply: Searching - Used 502 out there?
