-   -   Broken Bravo drive question (https://www.offshoreonly.com/forums/general-q/110049-broken-bravo-drive-question.html)
Interceptor 08-14-2005 02:16 PM
Pretty sure a drive let go yesterday. At first I though it was a coupler but could see the spline shat from the drive still spinning but no response from the drive when throttle was advanced.
Idled home on one engine/drive. Back at the dock the drive did engage and have forward/reverse at idle speed. Is it common to have drive at idle but it degrades as power is added ? Like the drive is slipping ?
ed
FOUNTAINATLAST 08-14-2005 02:38 PM
Re: Broken Bravo drive question
Normally when a drive starts to come apart you hear it making noise. I'd look alittle closer at the engine coupler, check to see if you see any rubber shavings near the back of the motor by the bellhousing....
HighPriority 08-14-2005 03:08 PM
Sorry for your bad luck, but if you need a drive I do have one for sale, and I have left or right hand.
Steve Snider 08-14-2005 09:20 PM
Sounds like a engine coupler to me. Pull motor time.
Mr Gadgets 08-15-2005 05:09 AM
Could be a shifting problem also.. do a search on shift problems and check the threads, the info was posted some time back.. to help you determine if it is a shifting problem..
34scarab 08-15-2005 05:49 AM
Could it be the hub on the propeller?
That sure would be a simpler fix.
They'll fail just like you described, you can idle in fwd or reverse, just can't give them any power.
Good luck.
Scott
GOODT 08-15-2005 06:23 AM
1 Attachment(s)
Sure it could be the hub, but same as with the coupler normally when they start to go they slip alot like a clutch in a car if you accel slowly they will grab a little. pull boat out of the water put it in gear and try to turn the prop.
what area are you in????
if you have anyquestions give me a call or email me
docmanrich37 08-15-2005 06:30 AM
Sounds like the same problem i had another boat and turned out to be the coupler.cheaper to fix that then replace drive.
Interceptor 08-15-2005 06:32 AM
Thanks everyone. I'm putting it on the trailer tonight and will report back.
ed
Interceptor 08-22-2005 10:49 AM
Turned out it was a spun prop hub.
ed
