v6 module ?s
I just got my boat together, the motors are hp500 efi long blocks with 420 mega blowers and 4-750holley--nickerson carbs with v6 modules.
when i set the total advance at 30 degrees and shut the motors off , it is hard to start- slow cranking. what is the cure ? if i back up the timing it cranks right over thanks for any help you can give kevin |
Re: v6 module ?s
Re: v6 module ?s
i have the trs outdrives so the starters mount on top fromthe back and they were both rebuilt before installed they look like a international starter
Re: v6 module ?s
1 Attachment(s)
heres a picture
Re: v6 module ?s
You might have to put the Merc starters on your engines.They turn over fine with the v6 modules.Check your grounds too.
Re: v6 module ?s
when i set the total advance at 30 degrees and shut the motors off , it is hard to start- slow cranking. what is the cure ? if i back up the timing it cranks right over thanks for any help you can give kevin Great to hear you have em' together. I'm looking forward to hearing from you on the cell phone when your on the lake in the 42! :D Dan |
Re: v6 module ?s
| All times are GMT -5. The time now is 01:42 AM. |
