Any PROVEN 500 hp Gen IV 454 Mags out there? >
Old 02-15-2006, 07:46 PM
Received 1,811 Likes on 901 Posts
Default Re: Any PROVEN 500 hp Gen IV 454 Mags out there?
The crane 731 cam will work fine and idle just fine. I put one in my 454ci/525SC. As far as making 500hp with it and the rest of your combo, I doubt you will, but it won't be that far off. I would guess you will more than likely be in the 450-475hp range. I would prop it to spin 5200-5400rpms.
Griff is offline
Old 02-17-2006, 06:25 AM
wtpowered's Avatar
Will I have reversion problems with the exhaust and a 731 cam?
Will it work with my heads?
wtpowered is offline
Old 02-17-2006, 02:01 PM
I don't know anything about the lift limitations of the 990 heads--They are the large oval ports, right??? I've only had rect ports. Reversion should not be an issue with the SM exhaust.
Griff is offline
Old 02-17-2006, 02:17 PM
CFD12's Avatar
Don't mean to interrupt, but I believe 990 's are the same as 188's.
CFD12 is offline
Old 02-17-2006, 03:09 PM
Originally Posted by wtpowered
I already have roller rockers and Stainless Marine exhaust. The last owner bought those. I was thinking of some light head work for better flow and to raise compression, a better cam, carb and maybe a different intake. ALL of this after the bottom end is freshened up. I don't really want to spend the $$$ for a stroker setup or to get a bigger (502) block. What kind of $$$ is it to bore the stock block a bit and get a set of good pistons??
I paid $1,200.00 for a used 502 block. I was told $1,800.00 new from GM.
lowflyin is offline
Old 02-17-2006, 10:51 PM
wtpowered's Avatar
After putting new bearings and re-ringing the 454 I definately do not want to buy a 502 block..........
I am done except for cam selection..................... Any more ideas guys?
I have 731 and 241 as suggestions. What are the pros and cons of the 2 cams?
Old 02-17-2006, 11:15 PM
I've used both cams. The 731 is a roller cam. The 241 is a flat tappet. The 731 will probably make about 20-30 hp more than the 241. The 731 will cost about $800 more for the cam and lifters and valve springs you will need.
The 241 cam is available in a kit with lifters for about $150. I have the exact part #'s at home. I'm at work now. The 241 cam is very close in specs to the stock 420/525SC cam.
Griff is offline
Old 02-18-2006, 09:04 PM
wtpowered's Avatar
Is there a tappet cam that would make more power then a 241?
If I can make good reliable power for less $$$$, I AM ALL FOR IT!!
Old 02-18-2006, 10:42 PM
dean51267's Avatar
I will have dyno sheets Monday night, will post when I get them...
dean51267 is offline
Old 02-19-2006, 03:53 AM
Yes, there are bigger cams that will make more power, but you will have to spin the engine at higher rpms. You will also loose some midrange power. That cam is good to 5400 rpms.
The crane part # is 134241. The part # for the cam/lifter kit is 134242.
specs are 226/236, .534/.553 on a 112 lobe sep.
Griff is offline
Quick Reply: Any PROVEN 500 hp Gen IV 454 Mags out there?
