Any PROVEN 500 hp Gen IV 454 Mags out there?
#31
Re: Any PROVEN 500 hp Gen IV 454 Mags out there?
Any ball park figures on hp with the 241 cam, Holley 800, roller rockers, 9:1 comp and stainless marine manifolds?
What should I rev this thing to?
#32
Originally Posted by dean51267
I will have dyno sheets Monday night, will post when I get them...
#33
425-450HP.
I had the same cam in a 454mag with roller rockers. Shaved the stock rect port heads and bumped the CR to about 8.9. Ran the stock magnum intake and a rejetted HP500 Holley 800cfm carb and Imco exhaust. I gained about 4-5mph. This would translate into about a 60-75hp gain over the stock 365hp. I spun it up to 5450rpms.
The bottom end had 400hrs when I redid the top. I put 50 hrs on it and the next owner put probably 100 on it. It was still running fine as far as I know and was pulled to put in bigger power.
Here's some old threads where I gave someone similar info. He dynoed the engine and was making 420hp @ 5000 rpms. That cam will make HP beyond 5000rpms. Spin it to 5400 and should be about 450hp.
http://www.offshoreonly.com/forums/s...ad.php?t=25932
http://www.offshoreonly.com/forums/s...ad.php?t=21543
#34
Griff,
Thanks for all the replies, you have no idea how much time I have spent looking at cam specs scratching my head..........
Also nice to hear I am not the first one to go with the cam/rollerrockers/carb/head shave combo!!
If I can I will have my motor dynoed and let you know how it turns out.
Thanks Again
Thanks Again
#35
Griff,
I was reading some old threads and see that you had the 454 in a 24' Baja....... I am in the same boat.
I was thinking of a rev 4 but I saw a post where you stated it didn't work well for you. What prop did you find to perform the best?
What kind of speeds did you get out of your 24?
#36
Fastest prop was a labbed 23 Mirage plus @5500 rpms. Saw about 65mph with it. Best all around ride was a 24 Bravo @ 5100rpms @ 61mph. Much better cruise speed and holeshot with the Bravo 1 and eliminated the porpoising that 24 OL's get easily.
#37
Get with Bob Madera, RMBuilder on this website. Give him all the information and let him select a cam for you. He is the best at this. Your combo should be good for about 450 HP.
