-   -   power steering pump (https://www.offshoreonly.com/forums/general-q/110256-power-steering-pump.html)
Dono 08-16-2005 02:55 PM
power steering pump
What type of lube goes in here? I have mayfair external steering. Also I have a marine machine resivoir that runs over to my powersteering pump. I had to disconect the hose in order to pull the motor out and red fluid came out kinda like trans fluid. I put it all back together and need to top off the resivior. Also do i need to bleed the system? I didnt let all the fluid run out but what if air got in? Thanks.
ratman 08-16-2005 06:38 PM
Re: power steering pump
i run atf in mine. i think if you fill it up and keep cycling up and down it will bleed itself
Dono 08-16-2005 09:50 PM
thanks, i thought it looked like atf and not powersteering fluid.
Dave M 08-17-2005 01:12 PM
I use ATF too.
hillbilly24 08-17-2005 04:37 PM
just make sure you don't use type F it will destroy the pump and the seals in the steering clyinders.
