-   -   Rec'd pushrods for 454?? (https://www.offshoreonly.com/forums/general-q/110306-recd-pushrods-454-a.html)
thebigtman 08-17-2005 07:31 AM
Does anyone have a preference on brands of pushrods or are the Mercruiser stockers the best for the money? I'm installing them on a 1990 454 (410hp).
Thanks.
Tim
San Antonio, TX
Pwrbt33 08-17-2005 09:16 PM
Re: Rec'd pushrods for 454??
I've used Manley's in the past. You could get away with GM ones if the motor isn't trick. Why waste the $. If you want better than stock then go with the mentioned or also Crane,Comp. Cams or even Summit.
Hope this helps.
John S. :D
