-   -   engine over heating problem (https://www.offshoreonly.com/forums/general-q/110659-engine-over-heating-problem.html)
ratman 08-21-2005 10:40 PM
stb eng over heats over 3200 rpms. running big offshore pick ups big kpm strainers that are clean, running 20lbs water pressure, fresh rebuilt raw water pumps, crossovers, no thermastat, flowing water out the exhaust but when i lean on it temp climbs right up, but it always runs 20 degrees hotter than its twin brother. yanked off the water pump before i went out today everything seems perfect impeller is in great shape. any suggestions? thx ratman
GOODT 08-22-2005 02:37 AM
Re: engine over heating problem
Hi ratman,
you didnt mention what motors you have so this is kind of shooting in the dark.... when you had the pump apart where there any scores high rpm overheat alot of times is cavitation in the pump caused by scores
ratman 08-22-2005 06:29 AM
goodt, 577 n/a's 9.4 to 1 comp. the pump was rebuilt and appears to be in great shape. i will take it apart inspect it a little better and replace the impeller.
Payton 08-22-2005 06:33 AM
Have you had an impellar go bad in that engine? Any chance of a broke off vane plugging something?
ratman 08-22-2005 06:39 AM
no, fresh motors, all new hoses, raw water pick ups, freshly rebuilt water pumps,
ratman 08-22-2005 09:35 AM
ttt
cooltoys61 08-22-2005 09:54 AM
Have you tried switching sending units or gauges? Is oil temp the same on both?
ratman 08-22-2005 11:27 AM
its getting hot the problem is not with the gauge or sender. my oil temp gauges are not wired properly and are not reading, i am having the oil temp gauges rewired this week.
ratman 08-22-2005 04:33 PM
ttt, any ideas folks? lil help here, thx
blue thunder 08-22-2005 05:48 PM
Brand new engines, but are the oil coolers new? Also any air leaks on the suction side of the raw water pickup with reduce flow.
BT :cool:
ratman 08-22-2005 07:12 PM
all the coolers are new with the exception of the p/s cooler, which happens to be on that motor thats getting hot. i will try swapping raw water pumps from one engine to the other and will back flush everything when i swap the pumps. any other ideas? thx ratman
cooltoys61 08-22-2005 07:21 PM
So what are the temps? If you have good flow from the exhaust I don't see how you could have a big problem unless you're really lean or way too much timing or something. Pressure means you pump is supplying but means nothing to flow,,but the exhaust flow tells you it's getting thru. I know from your nice hardware you probably know more than me , just trying to think this over with ya.
blue thunder 08-22-2005 07:24 PM
Do you run tstats and circulating pumps? If so, either of those could be suspect.
BT
thunderusone 08-22-2005 08:20 PM
If the timing has moved, IE dist issues or slipped, it will cause the temo to run up like you are talking about. It will also melt the engine quick. Get a timing light with an advance dial and check your total advance.
Liberator21 08-22-2005 08:48 PM
Ratman,
These are the engines that the guy did the not so great dyno job on?
You said the guy didn't really do any tuning on the dyno. I'm thinking along the lines of thunderusone. Timing? Carb Jetting? Are they set up like the other engine that's not getting hot? Lean carb/too much timing can make it get hot when you lean on it. Check the ps cooler, but check your plugs too.
See how they look, and compare them to the other engine.
You don't want to cook a new mill. :)
ratman 08-22-2005 10:27 PM
no thermastats, no circulating pumps, im running crossovers,
ratman 08-22-2005 10:31 PM
1 Attachment(s)
heres a pic of the dyno numbers bsfc #'s were .52 which should be enough fuel. i have 7 lbs on one motor and 5.5 to 6 lbs on the other at wfo throttle.
hillbilly24 08-22-2005 10:34 PM
I got a deal for ya Ratman, if you quit posting that sick krap in the UC section I will come fix your overheating problem. Deal ?
ratman 08-22-2005 10:40 PM
define sick, does that include getting the other engine to idle? i'll pay ya
hillbilly24 08-22-2005 11:24 PM
What aprt of Tampa do you live in ? I'm up in Hernando beach if your free Friday I can probably come check it out.
thunderusone 08-23-2005 12:26 AM
I still say it is timed to high on total advance.
ratman 08-23-2005 07:35 AM
hillbilly, i live on the water across from the oldsmar flea market, hillsborough and racetrack road, i may have it handled by friday though as i will start working on thing today. i keep you posted as to what i find. thx for your offer to help.
will check the total timing first and share my findings, thx ratman
