ZZ572 89 octaine?
Can you use 89 octaine with 9.6-1 comp.pistons or are you just looking for trouble?
Re: ZZ572 89 octaine?
please provide the following:
thermostat rating (150, 160, 170?) iron or aluminum heads combustion chamber design (fast burn/squish/quench) cam intake valve closing point and valve timing humidity and elevation also are contributing factors The most critical factor aside from the static compression ratio (CR) is the cam's intake valve closing point (and valve timing) a squish/quench design will allow you a few points on the CR aluminum heads will lower the combustion chamber temp allowing a few points on the CR too. With 9.6:1, iron heads, and a stock cam, detonation is probable with lower octane fuel. If you have large duration (aftermarket) cam and efficient heads than you should be able to get away with it. If you hear a tin-like pinging then use higher octane, retard valve timing, retard ignition timing, and/or run richer. What is the manufacturers octane recommendation? |
Why risk it...
On 100 gallons of gas here's the cost... 87 Octane - $245 89 Octane - $255 93 Octane - $265 The point I am trying to get across is that you pay $10 extra for a tank of 89, that's 2 octane higher than 87. Why not pay another $10 for 93 which is 4 octane higher than 89? My motors are 9.6:1 compression. Last year I used to run a combination of 87 and 93. That will give you the same cost as 89, but you will average 90 octane. After replacing 4 pistons on one engine, I decided to run 93 octane forever. |
Originally Posted by d1mbu1b
If you hear a tin-like pinging then use higher octane, retard valve timing, retard ignition timing, and/or run richer. ? |
thermostat rating (150, 160, 170?) iron or aluminum heads combustion chamber design (fast burn/squish/quench) cam intake valve closing point and valve timing humidity and elevation also are contributing factors The most critical factor aside from the static compression ratio (CR) is the cam's intake valve closing point (and valve timing) a squish/quench design will allow you a few points on the CR aluminum heads will lower the combustion chamber temp allowing a few points on the CR too. With 9.6:1, iron heads, and a stock cam, detonation is probable with lower octane fuel. If you have large duration (aftermarket) cam and efficient heads than you should be able to get away with it. If you hear a tin-like pinging then use higher octane, retard valve timing, retard ignition timing, and/or run richer. What is the manufacturers octane recommendation? This is a new boat I am building and I am trying to find a balance between spending way to much money on a custom engine build and a low hp engine Why would I use 89 Octaine? Thats all you can get around here on the water and the boat is way to big for me to take it out of the water just to filler up, 33 feet I will be using Stellings Dry Headers 2 1/8 primary Engine ? ZZ572 : recomended fuel 92 octaine (GM) Aluminum Heads agressive Cam 140 thermostat could be used Sea level use I may end up taking the 572 apart and changing out the pistons check all clearances including valve guides(these have been prone to failure I have been told on several occations) Thank you allonc again for your input and stories on this subject. |
I'd leave the timing alone and move up to the grade of octane it takes to stop the knocking.
Originally Posted by BajaIceBreaker
Why risk it...
http://www.sallee-chevrolet.com/Chev...ckV8s/572.html
here are some things for you to consider: recommended octane is 92 you should run 92 if you can only get 89 then... Since the ignition timing advance recommendation is 36 degrees, which is quite a bit, you can put a 140 thermostat in and retard the ignition a bit that may do it for you. this is probably the easiest solution. (Make sure though, you dont want to melt your pistons) Also, I understand there are aftermarket knock gauges out there the supercharged import guys use which may help you determine if the 89 is safe or not. Usually an EFI engine can detect detonation and automagically account for it some how, maybe by richening the mixture or retarding the timing (not sure exactly) I am surprised, it seems to me that 9.6:1 with aluminum heads is pretty mild. It must be that 36 degree total ignition timing as the culprit. |
just put a zz 572 620 hp in a 30 checkmate for customer . put timing at 32 not 36 had to go 1 jet size bigger on secondary he has ran couple tanks of real 89 oct with no problems and boat gps 80 mph
:drink: Anyone else using ZZ572 please chip in! |
| All times are GMT -5. The time now is 03:15 AM. |
