-   -   starboard burning more fuel than port? (https://www.offshoreonly.com/forums/general-q/111196-starboard-burning-more-fuel-than-port.html)
MILD THUNDER 08-29-2005 08:21 AM
My starboard engine is burning a lot more fuel than the port. Went out yesterday with full tanks, came home with one empty and one on half. It doesnt smell excessively rich, idles well, but starboard is down on rpm a little. The engines are in synch up to 3000 rpm, but when I go wot the port is at 4500 and starboard at 4000. Both engines have fresh tune ups, carbs are holley 800 double pumpers. No fuel in oil either.
Could the fuel pump be weak on the starboard, or maybe a clogged filter? That would explain the lack of rpm, but not the fuel consumption.
rob vanharten 08-05-2013 03:26 PM
Hey bud, did you ever figure this out? Both my engines are running awesome but the port motor uses about 25% more fuel then the starboard. Can't figure out why..... Fresh fuel filters, rebuilt carbs all the way around. Last time out filled both tanks to the top. Today refilled, starboard took 38 gallons, port took 51 gallons. Can't figure it out???
rob vanharten 08-05-2013 03:27 PM
Also just got boat back from the shop, both leak downs, and valve lash were excellent on both motors. They are both very healthy and in great shape. What would cause this?
ICDEDPPL 08-05-2013 03:38 PM
Hmm I also noticed my port eats more fuel.
rob vanharten 08-05-2013 03:47 PM
One thing I have noticed is when boat is just floating in neutral motors not running, my port prop is significantly harder to spin than the starboard prop. Could this extra friction/load make that much difference?
92nsx 08-06-2013 07:27 AM
^^^ Friction dose take more HP to over come, and HP takes fuel. Sounds like you have a winter project of a drive rebuild in front of you, is my guess.
ALL_IN! 08-06-2013 10:28 AM
My starboard engine uses more fuel than port. I never really measure the difference, but it is 5-10 gallons different usually (from my memory).
I assumed it was due to me using the starboard drive more (docking, trailering, etc).
Unlimited jd 08-06-2013 11:25 AM
Almost every boat I've been on does this, some more than others. My hawk with one tank 2 pickups the stbd dies about 2 min before the port lol so I'm guessing I have different pick up heights
CNC 08-13-2013 05:46 PM
Are the builds the same on both engines? have you checked O2 readings? Mine are within 1/2 gal on refueling....But I'm EFI
MILD THUNDER 08-13-2013 05:54 PM
My original post was from 8 years ago lol. I think the problem was ignitions. I replaced both distributors in those engines (they had points), and ran much better.
Lots of variables on why one engine might burn more fuel. Slight difference in prop pitch (very common in ssm props), idle mixture settings, jetting, ignition timing, one engine having a p/s pump, etc.
Rob, you really need to get those 02 sensors going, and see whats up. From there we can make some changes with carb's.
