Re: Hydraulic steering over 70 mph
From personal experience I can tell you that at any high speed maybe not even 70 it can be a life saver. My boat, a Cig Bullet handled fine with the stock steering, but last year the big nut that holds the arm like was mentioned above came off. The keeper had loosened up somehow. The boat made a violent left hand turn. Fortunately I had just slowed down from a pretty fast run, so wasn't running very fast, and was able to pull the throttles back and stop without any damage, except for a mess in my shorts. So a few seconds sooner and the turn probably would have thrown me out of the boat. And I was just about to go under a bridge and a few seconds later I might have made a hard left turn into one of the bridge supports. I understand with hydraulic steering that even with a line failure you won't get that kind of torque reaction and are alot safer.
So bottom line is go for it. John |
Go for it, I had cable to the helm with an external ram, and there was a good 2 inches of slop, wish I would of had full hydraulic, but still was better than stock.
Slop was kinda unnerving at 80+ though. |
Originally Posted by Ck1flyer
So, with these systems, do you eliminate the power steering pump all together?
I lost a PS belt recently and was still able to steer my full hyd dual ram steering with a little extra effort :drink: |
you can omit the p/s pump, and use a capalano helm which skater o/b 's use, but i would opt for the full hydraulic
system |
system |
keep this in mind too,if your running a nose cone or any kind of performance lower casing that also puts extra stress on your stock steering.Teague strongly reccomends AGAINSTstock steering and partial hydraulic steering with nose cones,its because the extra length puts stress on the steering system,Smitty
| All times are GMT -5. The time now is 01:45 PM. |
