-   -   Changing Props not Lower Unit (https://www.offshoreonly.com/forums/general-q/111507-changing-props-not-lower-unit.html)
MDB 09-01-2005 11:48 AM
I'm trying to figure out how to get a proper propeller for my soon to be re-powered boat without changing the lower unit of my SX leg. I went from a 3.0l to a 4.3l. Gear ratio is approx 1.97:1 currently. WOT should be about 4400 for the 3.0l vs 4800 for the 4.3.
Any ideas other than 200rpm per 1"pitch. How does the gear ratio affect RPM with a stronger engine same prop?
hillbilly24 09-01-2005 11:54 AM
Re: Changing Props not Lower Unit
What pitch were you running?
MDB 09-01-2005 12:08 PM
19"
East Coast B 09-01-2005 01:37 PM
Go to this BAM site and you can play around with plugging in numbers...
http://go-fast.com/Prop_Slip_Calculator.htm
What size and weight boat??
MDB 09-01-2005 02:11 PM
Will do! thx
It's a 20ft with cuddy...Apprx 3000lbs
